I've been doing some research and can't seem to find if this is possible
a NavPlus unit in my 99.5 A4. right now it's the non-bose system with a single din dash. I haven't found a write up for it, just seeing if it's possible.
If you have digital clock it may be possible
With a digital clock you have at least a CAN bus the RNS-E will talk to. In this case you would only need to convert to double DIN and deal with different time on your cluster and the RNS-E.
Without a digital clock there is no CAN in your car and you will loose for sure radio/navi display on your DIS. You would need to get a CAN adapter that makes a CAN signal out of your ignition/light/speed signal.
In either case you would have to deal with faceplate color differences and only 95% perfect fitment.
Search navplus.us for B5 RS4 or S4 projects, there are a couple. Without CAN and in a B5 I would probably go aftermarket instead of OEM.
e40
11-03-2006 02:05 AM
jaycurn
02-17-2006 09:23 AM
BTS4
08-05-2005 04:22 PM
TheDetailGuy(666PSI)
02-13-2004 07:30 AM
