01' 225HP AC Fuse Blew Now No AC.....
01' 225HP AC Fuse Blew / Replaced Fuse No AC.....
Replaced the fuse and now everyhing seems to work (AC light comes on) but no cold air just hot air blows ? Local shop did pressure test too and checked OK.
Compressor clutch is not kicking in
When setting the auto-climate control to allow for AC, the compressor clutch does not activate. Fuse had been replaced because it did blow and now the fuse remains good. Next steps I should look at ?
Check to see if there is 12 volt power to fan clutch . If there's power the clutch is probably burned out hence the failed fuse.
This just happened to me
The next thing to happen will be your electric fan will stop working and your car will overheat there is a relay or fuse block mounted on top of the battery mine shorted out I had it replaced problem solved. Hope this helps.
Mommy910
05-18-2018 09:36 AM
finashkey23
10-27-2007 04:13 PM
Old91CivicGuy
06-11-2007 10:32 AM
Jack in VT
Audi 100 / A6 (C4 Platform)
08-12-2005 06:38 AM
