Anyone know the VAG-COM group # for Air/Fuel ratio? Or do I have to calculate it from O2? (more)
I have been getting the "Long term:system too lean" CEL for a couple of weeks now and I think I have tracked it to a bad MAF.
I just replaced the original "non code" DV with the "N" code DV and cleared the ever-present CEL...OMFG this thing is fast. Drove for about a mile with a big smile on my face then the car went back to "dog mode". Drove for another 30 min and the CEL came back on. I get decent power at partial throttle and it feels like it is running out of breath at WOT.
I have noticed this 3 times now after clearing the CEL...Car is fantastic for about 5 minutes and then it goes to crap and about 30 minutes later the CEL comes back on. I've cleaned the MAF twice with no luck. I think the computer is adapting to the bad MAF readings which is causing the power to drop off and the cylinders to run lean... At first I thought it might be leaking boost throught the crappy DV but I have the same symptoms with the brand new DV and logged .74 bar (I'm unchipped), so I know I'm getting boost.
Am I on the right track????
Also, how the hell do you connect the vaccum hose to the top of OEM DV??? The clamp that clairparts sent me for the hose wouldn't fit until I bent it into a perfect circle!! So much for good clamping force...I bought some small band clamps like the ones on the other two hoses but I don't think they will fit in the recess on the top of the DV. Am I missing something or is the OD of my vaccum hose too big?
Thanks everyone!!
Thanks everyone!!
I didn't see it in this list but I'm not sure if this is complete for us
Andy@Ross-Tech posted this last week when I was looking for blocks.<ul><li><a href="http://andy.swankmonkey.com/vwfiles/datablocks.html">http://andy.swankmonkey.com/vwfiles/datablocks.html</a</li></ul>
Group#33 if I'm not mistaken. It displays the O2 sensors' voltage. Shouldn't get below 0.7 at WOT.
The lower the voltage the leaner the mixture. AT that list John posted below, it is group#33 for pre-cat O2 sensor (O2S1) and group#37 for post-cat O2 sensor (O2S2), but mine displays both at group#33.
Try this spreadsheet
<ul><li><a href="http://home.earthlink.net/~cogent001/vw/air_fuel_EXAMPLE.xls">http://home.earthlink.net/~cogent001/vw/air_fuel_EXAMPLE.xls</a</li></ul>
Andy
Andy
TTGram
11-02-2004 08:12 AM
Random CEL, CEL has been on for a couple of days now and I have VAGed the car several times (more)..
mullarks
08-03-2004 02:22 PM
T-28-Quattro de VT
12-30-2002 04:28 PM
