Bad headlamp sensor servo on LT FRT suspension?
Old May 8, 2006 | 06:01 AM
TittieTwister's Avatar
Junior Member
Default Bad headlamp sensor servo on LT FRT suspension?
Over this past weekend I noticed that my headlamps were abnormally low. They look like their hitting the ground about 30-40ft in front of the car. When I turn on the will do their normal slight up and down motion but they are still too low. I am wondering if the rattling noise I have been having for the past year is from the servo mounted on the lt frt suspension going out? Has anyone had one of these go out and is that what it might be?
Old May 8, 2006 | 11:44 AM
andrew.tt's Avatar
Default check to make sure the leveler arm is not disconnected >>
drivers side front and rear suspension. you'll see it - it's a thin steel arm that goes from the control arm to a sensor (black box) in the wheel well.
Old May 8, 2006 | 12:56 PM
Junior Member
Default Re: check to make sure the leveler arm is not disconnected >>
It's still on, I just wondered if it could be something internal on the sensor itself.
Old May 8, 2006 | 01:57 PM
andrew.tt's Avatar
Default it could be shot. you also may want to check your xenon's with >>
vag-com.
bimmerpwr
15
Jul 19, 2023 07:58 AM
Bladerunner
Jul 25, 2018 02:16 AM
hifiglie
Dec 7, 2016 09:54 AM
Dugzy33
Audi allroad
Oct 26, 2012 07:17 AM
zitrom27
Audi allroad
Oct 26, 2007 06:12 AM
