Blinkers crapped out
So for over a year now my blinkers every once and a while would stop blinking and just stay on solid when I tried to use them. Usually putting the hazards on for 10 seconds would make them "reblink." Now it's at the point where they pretty much don't work at all- the hazards do, but not the blinkers. Is the only fix to replace that module behind/above the stereo? Is it a pain in the ***? I thought someone on here had a connection to the module that has the "one tap blink 3 times" kind, maybe it was MarTT?
Also, the "one tap blink 3 times" ...
It isn't a special hazard switch, it's a separate euro-module that MCPi was selling (not sure if he has them anymore). It was definitely worth the $40.
Order the relay from worldimpex and we can change it at the gtg next week...>
I have radio keys if you need them, it is a really simple fix. Pull the HU (is it stock?) drop down a little cover and remove the relay. Should take 10 min max.
JMBlur
04-01-2008 02:05 PM
SparTTan
12-28-2004 07:04 AM
maurizio
07-12-2002 10:29 AM
