Brake problem ?
Brake problem ?
Hello,
From yesterday I have problem with my brakes. When I turn steering wheel to the end (left or right) and than first time when I press brake pedal, pedal is soft and deep; and car dont brake - then when I press brake pedal again it works normal.
Then next time when I will turn steering wheel to the end, first time after that brakes will not work (brake pedal is soft and deep again), when I press brake pedal second after that and than until I turn steering wheel to the end, brakes works normal.
Anyone know what that could be wrong? I have service next week, but Im scared I will lost brakes and crash into car at front of me.
Thanks for help
Thanks for help
I dont understand what is wrong with the sig?
I have same sign for Audi forum and BMW forum, until you no one didnt complain and I dont understant why would ?
Is this something wrong if someone has two cars and if someone has two cars will not get help on forum which is intend for help for one of those two cars you have ?
BTW: Ofcourse not from you, but from other members I have already get a lot of help on this forum
Sounds like the brakes need to be bled or could be a brake booster problem...>>
too. If you pump the brakes and they hold, you could have a air bubble(s) in the line.
How many miles on the car?
Have you had the pads replaced?
Since you have 2 cars, park the one with the problem until you get it to the dealer.
Hope this helps.
Hope this helps.
Thanks
Car has 60.000 km (convert: 37284 miles), brake pads were replaced 20.000 km (12427 miles) ago.
Yesterday after I drive out of garage (I turned steering wheel to the end) Ive seen that brake pedal is soft and deep, then I press it again and was OK. Then brakes worked normal (I didnt need to put steering wheel to the end) and today after I drive out of garage I had same problem again. Then I have tested brakes and every time after I put steering wheel to the end, first time pedal was soft and deep.
I will not drive TT until Ive got service. I thought that mybie brake`s oil lacks, but I dont see any connection between steering wheel and brakes. Strange is that if I dont turn steering wheel to the end (just normal moving in corners) it doesnt have any efects on brakes, only when I turn it to the end. On Board computer it doesnt show anything wrong.
Thanks for help!
Thanks for help!
Yep, I dont want to crash TT, because it is to good ;) I just want to know what is connection
between steering wheel and brakes - this could gave me information what could be wrong, before I go on service.
BTW: I know it is not for me, but what do you mean with "UT fan?"
wheel bearings.
Play in bearings (runout) pushes pads away from discs when lateral loads applied. See a mechanic.
msauve has trouble with noobs ;-) >>
I made a mistake when I was talking about my wheel adapters, and i got a bit of heat from him. all is good though, take the advice that the others gave in this thread
Anyone have the problem that feels like the brake pedal is sinking while your foot is on it?? (more)
EmCon 04
05-04-2006 01:15 PM
