Cold startup
Cold startup
Hi all,
I have a slight problem with my 1.8 tt.
On start up the engine runs rough for a couple of minutes then settles down, I also experience a slight loss of power at random times.
So far both Lambda sensors have been changed, along with the maf sensor.
The following codes were listed:
Catalyst system:
Bank 1: Efficiency below threshold:
P0420
Fuel trim: Bank 1 (mult): System too rich :
P1127
Pressure drop between turbo and throttle valve (check D.V!) :
P1297
Dump valve was replaced 2yrs ago and is working fine.
The codes, when cleared do not register again for 2-3 days.
Any help or indication towards this problem would be greatly appreciated.
Catalyst system:
P0420
P1127
P1297
Hello there,
I'm no expert, but it sounds like a small boost or a bacum leak. A cool trick is to light up a cigarette and move it arround the bacum lines to see if the smoke gets taken in.
Hope you can figure it out.
uber_ar
Audi allroad
03-22-2008 06:46 PM
MingsS4
04-27-2006 10:10 AM
Enne&Effe
04-17-2005 08:05 PM
