Eibach Pro-Kit : In stock anywhere???
Does anyone know of any place, anywhere in the USA, that has the Eibach Pro-Kit in stock? Eibach is on back-order till late this month - and I specifically am trying to get the kit before an event.
If anyone knows of any leads of a place that may have it in stock, please reply or email me - thanks!
If you only speak English, you can only import from the Australian or English distributor. The ....
story is that there are some Pro kits in the U.S. that were user risk test kits distributed. The Cali distributor will officially distribute after 04/30 only. # 1571.140 for quattro. Expect 2 degees off spec uncorrectable neg. camber in rear, which is still much less than H&R. Bring it in from the Fatherland is my motto.
Alignment after install.... possible? necessary?
From past experiences, which were from extensive modifications to my 1995 and my 1998 Dodge Neon race cars, you usually had to do an alignment after the suspension was played with. Of course, you might only have so much alignment you can get, but it still was required.
With the dealer installing my Eibach Pro-Kit for me, do I need to askt hem to do an alignment afterwards? Or will that not even be necessary? Or do they do an alignment, but they'll only be able to get it "so good" which wont be to factory spec, but will still be necessary to do their best after the install?
Thanks..
Shaka!
Thanks..
Shaka!
UCityCoupe
28
08-28-2001 06:04 PM
Stoyak
02-28-2001 04:29 PM
