Engine coolant temp and poor gas mileage
2001 audi tt quattro 225hp
36k miles
original and mint
Cluster temp gauge rarely gets above 70c
When I run the coolant temp through climate display (code 51c) temperate slowly but steadily climbs to 90c (takes quite a while) and then the fan engages and maintains 90c. No overheating.
Heater core works great - cabin is warm within 5 mins.
However:
Fuel consumption is very high - just over 10 litres per 100 kilometres of highway travel - supposed to be about 7.7 litres for every 100 kilometres of highway travel.
Any suggestions on coolant sensors, thermostat or troubleshooting?
Thanks in advance.
36k miles
original and mint
However:
Thanks in advance.
Ys that is the symptom of a stuck open thermostat. One other thing. Use block 49 in the HVAC control to see actual real time coolant temp. Block 51 is levelized IIRC.
Replaced thermostat - running proper at 90 degrees on both analog gauge and block 49.
Question - all came apart and went together fine, save for the alternator strap retainer nut - dropped into the abyss behind the alternator mount.
I believe it is a 8 mm nut - does anyone know the exact specs - the thread pitch?
Thanks for the diagnosis. I've got exactly the same problem with mine (63K kms on the odo).. Read in another posting that if the temp gauge is running low, and '51C' is reading at proper temp, then the instrument cluster will need a rebuilt as the gauges are not accurate. I'll try '49C' tomorrow - didn't know about that one.
TVonaStone
Audi 100 / A6 (C4 Platform)
04-08-2015 06:38 AM
ROCCO_16V
Audi Original "S" Cars
08-23-2009 04:53 PM
BoostFrenzy
12-27-2004 09:57 PM
The Mystro S4
04-16-2004 05:07 PM
Jay 225TTR
9
05-15-2001 08:34 AM
