Engine running like hell! Help!
Old Oct 12, 2005 | 02:01 PM
  #11
Sully's Avatar
Member
Default Re: Sounds like a bad CAT possibly
Catalytic Converter? How is that? Ok...exhaust/compression, I think I understand...the foot bone is connected to the leg bone, the leg bone connected to the hip bone, etc, etc, etc...
Old Oct 12, 2005 | 02:11 PM
  #12
JohnLZ7W's Avatar
Default Still want to race?
Or maybe check codes with Vag-Com?
Old Oct 12, 2005 | 02:18 PM
  #13
Airbag79's Avatar
Default A bad CAT will cause all of the problems you are experiencing>>
bad coil packs/plugs won't cause a rough start up. A vacuum leak could cause rough idle, won't cause rough start, and won't affect when you get on it, a bad CAT will. Just my .02
Old Oct 12, 2005 | 02:19 PM
  #14
Sully's Avatar
Member
Default John, the answer is yes...>>>
but you may have me beat being engine problems here, but worth a go to settle my curiosity, and it will be nice that I don't have to flip you off for beating me in the race! LOL! Yes to the VAG-COM as well. Let's rent the track at PIR!
Old Oct 12, 2005 | 03:17 PM
  #15
kodeTT's Avatar
Elder Member
have you considered the fuel filter?
Old Oct 12, 2005 | 03:23 PM
  #16
Sully's Avatar
Member
Fuel filter? Hmmm? That sounds credible.
Old Oct 12, 2005 | 06:08 PM
  #17
kodeTT's Avatar
Elder Member
Default i changed mine at 35K regardless of what the Audi service guide says.
but you would think that a not so expensive part could do if it were clogged up. I didn't want to take any chances, so i figured it was due for a swap.
Old Oct 12, 2005 | 07:05 PM
  #18
TTagz's Avatar
Senior Member
where is it located?
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 28, 2005 | 11:00 AM
  #19
gfbemc's Avatar
New Member
Default Re: have you considered the fuel filter?
Hi; I can not figure out how to release the plastic fittings on the 2001 Audi tt Quattro. The fittings on my car are different then the ones posted in the forum. Do I need a special tool? Thanks
Busted_A4
Mar 24, 2008 08:54 AM
gonutz
Sep 21, 2006 05:02 PM
Rosati (Ginzo)
Aug 28, 2006 05:53 AM
petervan
Oct 1, 2005 03:31 PM
canonicalman
Apr 15, 2004 02:58 AM
