ESP/ABS problems
ESP/ABS problems
My 2001 TT roadster (2wd)has developed two perplexing problems. They began after a wheel alignment.
1. 3 times in two weeks, at speed on the interstate, the steering will suddenly pull to left (not a huge amount) accompanied by the "gronk" sound that ABS can sometimes make when braking hard! Scare the bejezzus out of you.
2. At some point on nearly every trip the car makes, the ESP/ABS light will come on when braking. No physical symptom in this case.
I don't have an Audi dealer close, and the VW dealer who services the car normally is baffled and says it's time for me to take it to an Audi dealership. That's a full day's event for me.
Any suggestions, either for fixing, or that I can pass along to service writer/tech at Audi dealership? I've learned I need to speak in their language if at all possible.
Thanks
Sherry
Thanks
Sherry
ESP has a sensor to know where the front....
wheels are compared to the steering wheel position. If the alignment is changed and the sensor is not reset the ESP program will think the car is in an abnormal driving condition and try to correct.
VW's do not have such an ESP sensor...
I think you may have hit the nail on the head.
A call to the VW dealership which performed the alignment says that VW's don't have this sensor, and therefore resetting one is not something they do.
If you're correct about all this, then a new alignment or sensor resetting at an Audi dealership should solve the problem.
I'm going to call the Audi dealer service dept. and see if I can get confirmation on the problem and solution before dedicating a day in their waiting room.
Thanks
Sherry
Thanks
Sherry
I don't believe that. The steering position sensor is what is used by the ESP system to determine
your intended direction. If it has ESP, it needs to know where you want to go, and it needs a steering wheel position sensor...
LCP
09-02-2003 09:50 AM
ONYX
09-11-2001 07:04 PM
