Fault Code issues, help?
Old Dec 17, 2005 | 11:00 PM
MeehowTT's Avatar
Default Fault Code issues, help?
Still going soft limp at random times, seems like only at half throttle, I thought it was the DV, changed it out to the stock one, same thing. Here are my codes!
17965-Charge Pressure Control: Positive Deviation P1557
17705-Pressure Drop between Turbo and Throttle Valve P1297
Any ideas what to do next?
Old Dec 17, 2005 | 11:14 PM
TwisTTer's Avatar
I have the same symptoms...have you tried changing the MAF...seems like a a common culprit
Old Dec 17, 2005 | 11:18 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default Have you tried looking for any of the issues mentioned that last time you posted?
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1406617.phtml">https://forums.audiworld.com/tt/msgs/1406617.phtml</a</li></ul>
Old Dec 18, 2005 | 05:47 AM
BierBurner's Avatar
Have you used eBahn Reader yet. I will check it out.
Old Dec 18, 2005 | 06:17 AM
BierBurner's Avatar
Default Okay, I checked my eBahn reader
To start off.
Code 17965: Check N75 Valve operation
Next
Code 17705: this will be more difficult because of more leakage points.
eBahn says to check the Connection of charge throttle valve. Therefore check the hoses BTWN Turbo and Throttle Valve. You will check the pressure drop using VAG tool 1687. I think Steve(ModshackTT) might have a similar tool. Good luck. If you have any more specific questions like specifics. let me know. What year and engine you running. AMU ?
Uriah
Old Dec 18, 2005 | 06:57 AM
MeehowTT's Avatar
yes, I got a new MAF
Old Dec 18, 2005 | 06:58 AM
MeehowTT's Avatar
Yep, I don't see a boost leak
Old Dec 18, 2005 | 07:00 AM
MeehowTT's Avatar
Default Ok,
Well that sheds some light, I guess I should do a boost leak down test, using Steve's thingiemajig...Thanks for your help!
 Michael S. Palmer
Old Dec 18, 2005 | 07:24 AM
BierBurner's Avatar
You bet. Did you read my other post, about the N75 Valve. code: 17965
Firefighter
A4 (B8 Platform) Discussion
Dec 17, 2016 01:53 PM
torpilas
VAG-COM Discussion
Dec 10, 2006 04:28 PM
Jim - 03S8
Feb 9, 2006 07:59 PM
EasTTcoasTT
11
Sep 16, 2003 07:41 PM
yzf996fltri
Audi allroad
12
Sep 6, 2003 08:40 PM
