Fault / notes detected...(long)
Hey all! I have a series of faults going on with my car. It's a 2001 Coupe. It was involved in a major accident a while back and I'm starting to "try" to fix things here and there. I went to the dealer about a month or two ago and I got it diagnosed. See if anyone understands any of this and can help me with what I need to do or buy to get some of these things fixed. You all are probably going to tell me to just trash the vehicle but there seems to be nothing wrong with the way it rides or handles. Here's the readouts..
16486 P0102 035
Mass or Volume Air Flow Circuit
Low Input
16518 P0134 035
O2 Sensor Circuit, Bank1-Sensor1
No Activity Detected
16524 P0140 035
O2 Sensor Circuit, Bank1-Sensor2
17522 P1114 035
Bank 1, sensor 2
17876 P1468 035
Evaporative Emission (EVAP) Canister Purge Solenoid Valve -N115-
Short to Ground
17880 P1472 035
EVAP Emission Control LPD Circuit
Short circuit to Ground (GND)
18057 P1649 035
Data-bus-drivetrain
missing message from ABS control module
sporadic
00283 035
Front left speed sensor -G47
00283 016
Signal outside tolerance
sporadic
00285 035
Front right speed sensor -G45
sporadic
00778 027
Steering angle sender -G85
implausible signal
sporadic
00812 035
Brake Pressure Melease Solenoid -F84-
00814 035
Brake pressure solenoid in brake servo -N247
01044 035
Control unit incorrectly coded
01312 037
Drive train data bus
faulty
01314 079
Engine control unit
check DTC memory
01314 049
Engine control unit
No communication
sporadic
01324 049
All-Wheel Drive Control Module -J492-
No communication
sporadic
01423 057
Lateral acceleration sensor -G200
electrical fault in circuit
00778 049
No communication
So yeah, I got a printout that had those on them from Baillargeon Audi. Steve Fordham was the man who helped take the time to look at everything and give me this printout. By the way, thanks Steve for all your help. Anyways, from what he was saying was the main problems were due to my ABS/ESP system not working. He said I would need a new ABS Control Module. After that, I didn't understand a word he was saying. Haha...but ok, if anyone understands any of this just leave me an email or something! Thanks for looking.
Nathan
16486 P0102 035
Low Input
16518 P0134 035
16524 P0140 035
17522 P1114 035
Bank 1, sensor 2
17876 P1468 035
Short to Ground
17880 P1472 035
18057 P1649 035
Data-bus-drivetrain
sporadic
00283 035
00283 016
sporadic
00285 035
sporadic
00778 027
implausible signal
sporadic
00812 035
00814 035
01044 035
01312 037
faulty
01314 079
Engine control unit
check DTC memory
01314 049
Engine control unit
No communication
sporadic
01324 049
No communication
sporadic
01423 057
00778 049
No communication
Nathan
2 things:
1) if you're relying on the dealer to pull / interpret codes, you're kind of over your head. hell, with that list i'd be thinking of bailing on it myself.
2) so you're ignoring my words above and going on with trying to fix some of it yourself. well good for you! this isn't going to be easy. get a vag-com 1st thing. you'll get nowhere otherwise. clear the codes and see which ones come back. then with the help of the forum you can start working your way down the list.
tartar
07-13-2010 07:19 PM
PKmode
09-25-2006 10:53 AM
