Final issue with my TT - Purge Valve? Evap Issue
Since I bought my TT, I've had issues here and there. This is the final problem.
CEL, Evap Leak
Code P2404
I've researched this a lot, and I've come to the conclusion that it's my purge valve (N80)
Reasons:
Now, since I'm not 100% sure about this, would you guys recommend I check some other things before replacing the valve? Any DIY guides? I have the Bentley manual and I've heard it takes an hour or two to do, but would you just recommend I pay a mechanic $200 to do it? And finally, is the correct part for my 2002 Audi TT Quattro 225?
There's a smaller issue, by the way, and I'm not sure if it's related. The fuel gauge shows more gas than is actually there. However, I've read that it's because of the signal sender corroding. Could this cause the CEL or is it unrelated?
Thanks
CEL, Evap Leak
Code P2404
Reasons:
- Car has a lot of gas vapor when I try to put fuel in, I have to air it out before putting gas or it won't take any
- Car began overflowing gas (happened once)
- There's no gas leak anywhere under my car
Thanks
carl viking
36
04-27-2020 01:17 PM
raiderrider
12
09-08-2015 05:46 AM
elem
09-07-2015 01:04 PM
TrailAgent
09-06-2015 12:15 PM
