FINALLY, ModShack Stage 3'd! Need a lil' help here...>
I can finally join the modshack club after today's install. I had to get the older model TT coolant temp sensor, not the green one, at the stealership for $42!! Is this price correct, because the green one's are only 5 bucks. In any case, I figured with the rough idling, I should replace it before doing any mods. With the temp sensor replaced from a blue squared connector one to a black connector temp sensor, I was ready to start modding. After I finished the installation. I took her for a test drive. As I stepped on and released the gas, a whistling noise could be heard. I kind-of pinpointed where the noise might be coming from. It was around the N75, where I just hooked up the boost machine. It sounds like a leak of air from one of the connections, but me and a buddy double checked them and they all look good. The leaking air sound is killing me. Help? Any tips?
Step one, gather up all the goodies.
<img src="http://pictureposter.audiworld.com/64925/presents.1.jpg">
Installed everything.
<img src="http://pictureposter.audiworld.com/64925/picture_009.jpg">
Where the vacuum leak sounds to be coming from.
<img src="http://pictureposter.audiworld.com/64925/picture_006.jpg">
<img src="http://pictureposter.audiworld.com/64925/picture_005.jpg">
I have yet to adjust the boost machine, or install the boost gauge so...
I don't have any numbers yet. But the noise doesn't sound like a consistant "shhhh." The pitch gets really high while driving like air coming out of a balloon. Almost sounds like squeeling, I wish I could record the sound. I'm going to try to record the sound, but it probably won't turn out. Should I start playing with the boost machine a bit w/o the guage and maybe the noise will change?
Pull the BM out and see if it goes away. It may be the TTDA - it lets alot
more turbo noise "out" than the stock box. This is not a problem, just a difference between the two.
808Guy
03-14-2003 05:32 PM
