Frequently Asked Questions and Common Problems Thread Collection
Old 06-13-2006, 01:13 PM
  #191
MCPaudiTT - DEFCON 1's Avatar
Default What does ABS, ASR and/or ESP mean/do?
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1507444.phtml">https://forums.audiworld.com/tt/msgs/1507444.phtml</a</li></ul>
Old 06-13-2006, 02:22 PM
  #192
eTTie's Avatar
Default Oil dipstick tube install
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1506220.phtml">https://forums.audiworld.com/tt/msgs/1506220.phtml</a</li></ul>
Old 06-14-2006, 06:46 AM
  #193
AudiWorld Uber User
TTschwing's Avatar
Default Haldex Diagnostics and testing...>
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1452481.phtml">https://forums.audiworld.com/tt/msgs/1452481.phtml</a</li></ul>
Old 06-15-2006, 08:53 AM
  #194
Senior Member
XCLR8TT's Avatar
Default Is my dealer any good? Dealer Ratings and Tuner shop ratings
<a href="http://1.8t.org/dealers/">Dealer Ratings</a>
<a href="http://1.8t.org/tuners/">Tuner Ratings</a>
Old 06-17-2006, 03:42 AM
  #195
AudiWorld Uber User
TTschwing's Avatar
Default Camber change and lowering....
or why correction kits are necessary.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1101053.phtml">https://forums.audiworld.com/tt/msgs/1101053.phtml</a</li></ul>
Old 07-06-2006, 11:39 PM
  #196
Default Full interior Tonneau cover for Roadsters...
This one took a bit longer than planned. 2 hours of work, 2 hours locating bits that have fallen in to vents, cutting off drill bits to fit tight areas, almost stripping screws, etc.
Anyway, here are the end results (for a full write-up, follow the the link below to the original thread, then to my Fotki):
<img src="http://images2.fotki.com/v327/photos/4/435091/2737221/57Allbuttonedupb-vi.jpg">
<img src="http://images17.fotki.com/v325/photos/4/435091/2737221/59Allbuttonedupb-vi.jpg"><ul><li><a href="https://forums.audiworld.com/tt/msgs/1518695.phtml">Original thread</a></li></ul>
Old 07-11-2006, 08:36 AM
  #197
AudiWorld Uber User
TTschwing's Avatar
Default Excellent TB "How to" from the UK....
<ul><li><a href="http://www.amp82.co.uk/tt/timingbelt/">http://www.amp82.co.uk/tt/timingbelt/</a</li></ul>
Old 07-13-2006, 07:13 PM
  #198
SparTTan's Avatar
Default Replacing after-run coolant pump
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1521900.phtml">https://forums.audiworld.com/tt/msgs/1521900.phtml</a</li></ul>
Old 07-26-2006, 11:00 AM
  #199
JazziTT's Avatar
Default No need to remove the connector bail wire
I drilled out the rivet (1/8 drill bit) and riveted bracket back onto new pump
Old 07-26-2006, 11:04 AM
  #200
JazziTT's Avatar
Diagram shows pin #10 (don't see a #19)
Quick Reply: Frequently Asked Questions and Common Problems Thread Collection
