Grounding a 180Q....question...
stupid question..i have everything grounded except the driver fender to the neg battery...i dont have enough room on the bolt for the battery. should i just get a longer bolt or is there another place to ground the fender...thx for the help
When Ed (TTakes2) and I did ours, we......
<center><img src="http://images9.fotki.com/v189/photos/4/469393/2395071/SPA0081-vi.jpg"></center><p>had 2 already on the front side of the bolt, so we used a spade connector on the back (head) side of the bolt to the torx head bolt on the horizontal part of the fender just near the headlight.
So if I go from..
the trans to driverside fender it will be ok.
so far it goes...
1.battery to trans
2.TB to battery
3.Valve cover to coil pack
4.valve cover to trans
5.TB to pass fender...
so far it goes...
1.battery to trans
2.TB to battery
Don't bother, and tell yourself you did...
it will have the same effect. Grounding does nothing on a properly designed car.
Go ahead, measure siemens before and after, I'll bet you won't see any difference.
Info >>>
Most stock cars, including the Audi TT, has a stock grounding system that consists of just a couple of cables that connect the chassis and engine to your battery's negative terminal. Grounding wires are the foundation of all car's electrical system (ignition system, coil packs, spark plugs, lights, fans, stereo, air conditioner, cigarette lighter, etc). Resistance, in the form of electrical impedance, is the enemy of all car's electrical equipment. High quality grounding cables minimize resistance and help make sure that all of the electrical equipment in the car is performing as well as it can.
