Help! Check engine light came on tonight on drive home from dinner.
Are there any obvious things I should look at. Clearly I can't get maintenance until monday, should I drive the car tommorow? BTW the car feels and sounds normal. Thanks for any and all responses.
Will do, but I doubt this is the problem...
as I am down to a 1/4 tank of gas. The problem seems to have occured when I returned to my car after dinner and started it, then I had to turn it off to talk to someone. Five minutes later I cranked it up and then the light was there. Anyway, I will try your advice as this is the simple type solution I am looking for.
I've had it happen several times & it was the gas cap also...
If the attendent doesn't make that clicking sound w/ the cap the light goes on. It may also take a few days to a week to go off. Fill it & close the cap yourself.Also I would check my oil as a precaution. You can also disconnect the battery & let the computer reset itself but with the TT there maybe other complications to doing that.
AzIvy75
12
11-01-2009 07:33 PM
Carlos Ramirez
Q7 MK 1 Discussion
07-02-2007 03:07 PM
Dennis H.
09-04-2001 04:40 PM
Gorobei
11-14-2000 09:26 AM
