Mental meanderings at a local auto show ... how to "better" the TT (is that possible?)
I was at local auto show recently and saw something that I'd seen before on SpeedVision. Someone had taken the handles off both doors of a chop-top truck and re-machined the door panels so that they're completely flat (showing no signs of a handle or ever having a handle). They then hooked up the truck's keyless entry system to electronically open the door.
In a word: bad-***. I think that would look so cool. Of course I'm sure the cost would reflect that "coolness" but it was just something I thought about.
Any thoughts on this? Or how much a setup like this might run?
I know the nay-sayers are going to harp on how impractical it is (should the battery die, etc.), but if I had more $$ than I knew what to do with ...
It would be less visually distracting, but...
considering how many peeps have had window/other electrical problems, I wouldn't want to completly reliant on an electronic entry system...
Its called shaving the doors and the electronics are about $200. find a custom mag
like lowrider. Also, you will need the handles filled shouldn't be more than $500. Step one weld a wire mesh in the handle hole. second use body filler. Then smooth to then paint.
anilx783
Q7 MKII Discussion
11
03-31-2018 05:20 PM
leTTcco
12
02-19-2005 08:03 AM
chillzatl
11
01-29-2001 05:22 PM
peterc
01-07-2001 05:37 AM
Rennen
14
11-02-2000 05:03 PM
