Mobil 1 oil: Protection or Performance?
I am almost up to my first oil change and I read a lot about forum members using Mobil 1 instead of what the dealer will supply you with.
Bottom line: will Mobil 1 synthetic give you actual improved engine performance or it is just better for the engine in the long run so it will last longer with fewer problems?
Thanks for the info!
Both...but very slight on the first issue...better lubricant less friction less HP used for internal
workings of engine. Wear & tear...having the lighter weight trisynthetic means when engine has been sitting and you do cold start the lighter lub makes it to the engine friction points faster than the more traditional heavy weight dino juice...Mobil 1 (or other good synthetics) is just a better way to go than standard oil.
roots
01-23-2003 09:02 AM
ryno
07-31-2002 10:16 PM
