More (cleaner) pics.
washed car
<img src="http://users.sisna.com/Rave_nGTI/clear3.jpg">
<img src="http://users.sisna.com/Rave_nGTI/clear3b.jpg">
<img src="http://users.sisna.com/Rave_nGTI/clear4.jpg">
<img src="http://users.sisna.com/Rave_nGTI/clear5.jpg">
<img src="http://users.sisna.com/Rave_nGTI/clear5b.jpg">
thanks steve!! and a question for you>>
it seems the bottom inside (by grill) of my headlights stick out past the bumper a bit now... that or the bumper is in more... I got all of it adjusted to where the hoood gaps are close to what they were before. Have you noticed this as well? did I not stick the headlights back together enough? I did get the clips back on!
I dunno.. maybe it was always like that and I just never noticed before.
If you got the clips on..>>
I think you're good. It may be that you never noticed before... One little trick that I've seen some miss, is to make sure the rear pivot mount for the light (inside the fender well) is engaged. Without this 4th point, the lights could look a little wonky. You're first pics looked like that, specially the right, but the ones above look fine. Didja get those in? If so, Maybe just a little more adjusting will get you there...
The same thing happened to me after I removed...
my reflectors. Seems like the corners stick out a little further. I was wondering the same thing, but in the end I think it's the bumper cover is in a little further. I tried adjusting the lights as much as I could, but it was still there. What did you do about the holes left from where the reflectors were?
