New GIAC + DV = Holy Crap! + 5550 rpm cutout + whistling noise
I've got 2 problems that have cropped up after the install.
1. A whistling noise at some rpms under full throttle. I had the GIAC installed and drove home to do the DV myself. The whistling noise didn't start until immediately after the new DV was installed.
2. Power cuts out at about 5500 rpm some of the time. Seems to happen more in 3rd/4th than 1st/2nd. This occured before and after the DV.
I searched and found other people with these problems, but couldn't find a reported fix. Any ideas what is going on? The car is a 2001 with 20k miles.
2- when you say...Cut's out....describe the feeling...is a sudden loss like hitting wall???
Some cars with mileage, that get chips, expose a MAF that is failing....
Also, was your GIAC software flashloaded??? Some have experience a higher level of boost with recent flashloads than some previous versions of the software. So you could also be hitting a "soft limp" mode with the sudden cutout as you call it.
More info please! ;-)
2. The cut out could be similar to hitting a wall, running stone cold out of gas, etc. It's similar to if you were runnign full throttle and someone turned off the car with the key, but not quite that dramatic. It only happens some of the time.
GIAC was flashloaded. I don't have a boost gauge.
