Ok, went on and purchased portfield pads , kind of
expensive $200 for all 4. mmmm........
But what about this process??
6 Breaking in, the "Burnishing Process" . . .
After prepared and treated rotors are re-installed to their original positions, test drive the vehicle braking very gently from 20 mph to 5 mph without coming to a stop. Repeat 10 times. Then brake normally from 40 mph to 10 mph. Repeat 10 times. Allow one-half mile cool off between slow downs. No "panic stops" for the first 300 miles. If you are breaking in new rotors, park your car for one hour, after above slow down cycles. A gradual cool down, for one hour, avoids warping your rotors.
anyone here done this?
I did it and they started squealing after 400 miles. Interestingly if I repeated it they would...
stop squealing for about 100 miles. But it always came back. Finally switched to Mintex red box. Others have had no problems with Porterfield. It seems most of those did not have stock rotors (though not all...)
Not trying to bad mouth the Porterfields but you should know. Also Mintex 1/2 the price of Porterfields. A little more dust than the Porterfields but still much less than the OEM.
Bedding pads sounds pretty easy. I bought a set of
Pagid orange pads for the track. They are considered racing pads and the procedures for these are "90 to 65 with moderate pressure, 3-4 times, followed by 110 to 65, with medium to heavy pressure, twice. I found a place to do it, but I wasn't comfortable. The brakes really work well.
q2quest
03-10-2005 07:48 PM
q2quest
03-10-2005 07:26 PM
DLG
02-07-2003 02:45 PM
ChrisS -2008 A6-4.2
11
08-20-2002 05:38 PM
