Orbital buffer usage- tips, etc?
I want to get rid of all the swirl marking in my black paint. Also I have 2 very fine scratches that I would like to work on. I have some 3M swirl remover stuff and Zaino of course. Can I apply both of those with this machine? I am kinda leery about the swirl remover, since I think this buffer has a lot more power then when I do it by hand. So if anyone can shoot me some tips and how-to's I would appreciate it.
PS: the buffer is on where the pad spins and the whole head rotates also. My friend said you just go in lines, and NOT to use it on plastic, since it will melt- which means no backend I guess.
Really, to use an orbital, all you need to do is put a very small amount(1/2 tsp) of whatever you're using and run it over the paint until you stop seeing the product spreading anymore. Then start all over again until the whole car is covered.
Here's an extreme example. I spent quite a bit of time today helping my ex-wife get her Blazer ready to sell. The paint was in such poor shape that I ended up having to wet-sand the whole hood and some of the rest of the body.
<img src="http://albums.photopoint.com/j/View?u=1435687&a=13229482&p=50166175">
Of course, wet-sanding leaves nothing but thousands of hair-line scratches in the paint. An orbital won't go very far in removing these. The only way to really go after scratches is with a high-speed buffer.
Anyway......you may be able to remove most of the swirls with the orbital, but high-speed is the only way to remove scratches unless you want to try to work them out by hand with a more abrasive compound.
Thanks Jason!
I, personally, wouldn't use an orbital machine.
Paul
LOVE the results. So much faster. Use very little wax. Results are soo much better.
I'm sure there are other random orbits out there. No experience with them. Since I do woodworking and can appreciate Porter Cable. It was a no brainer. PC IS the best. You can feel the quality (and weight) of the unit. Put together great. Well balanced.
Paul
Just re-read your messge. If it is an orbital (not random orbit), I have no idea.
The Random orbit will remove swirl marks (with a good polish) and lighten scratchs a lot (again, with a good polish)
JUST SAY NO TO COMPOUND. a good cleaner/polish/wax will work very well for black cars. It should look wet when you are done.
wash car
dry car
clean paint (clay bar or 'cleaner' -like meguiars step 1)
apply quality polish
wax entire car...
THEN wax again, over wax, without removing first wax.
Wait 5-10 minutes (depending on brand)
remove wax with Cotton towel or approved microfiber towel - change towel frequently
If you used a quality polisher (PC or others) wax removal will be real easy (right Sandra??)
Paul
