Paging MEEM and KodeTT
Hi both of you.
I finally got my KW and my LM147... What a nice piece of wheel. I am now installing the the KW and I was wondering about the height setting of the front. I found all the info I needed for the back (1011 coils I received) but for the front setting, there is like 4 inches if threaded body to adjust...
By looking at both of your cars, the setting looks just fine for me. I was wondering if you had the measurement of the shock setting in the front.
For the back, I am installing them with the eperches in the normal position and to the lowest setting and it is looking fine for me now.
Thanks.
Dominic
Thanks.
Dominic
it was just trial and error...but the rear perches was flipped with white spacer removed...
in the front...there's about 1-1/8" threads left to the bottom perch. the rear 1011 coils are taller than the 8012 coils.
Re: it was just trial and error...but the rear perches was flipped with white spacer removed...
Thanks,
UI set it up leaving 1 1/16 for now and will re-evaluate, bring it a little higher once the coils settle down for one or 2 weeks,
Thanks for the info. I am planningnon the back this week
Dominic
Dominic
the 1011's will only drop it to a point with reversed perches...if you want to corner
balance, i would start with using the 8012 coils and be done with it. it is 10mm shorter, which will allow you to use the perches in the correct configuration and even corner balance the car the proper way.
NJ1.8
01-12-2008 09:08 AM
ydowork
04-10-2006 07:55 AM
AWOT extra 23052
Florida Discussion
04-22-2003 05:41 AM
