Recomendation please, Stratmosphere TT (camber adjustable) tiebars or Kmac kit? Both are $250
Kmac allows you to ...>>>>
easily adjust toe (if you install upper and lowers). Not so with the other Tie arms (you must adjust the suspension trailing arm....not so easy)
Just something to think about. Proper suspension alignment is more than just Camber correction.
Depends how low you are. I'm just a bit shy of 1.75 lower than stock>
and the Strat arms "just" bring me into specs. If you're not any lower, I'd recommend them. They use ONLY brand new arms, and factory bushings. That way, all your suspension bushings match. Very nice build quality. Make sure you find a real good shop to do the allignment.
SprinTTer
03-11-2003 11:18 AM
