Remote Key Replacement question
Old Apr 4, 2006 | 08:48 AM
TraderVic's Avatar
Default Remote Key Replacement question
If I buy a used one from eBay, how do I know if I can reprogram it? Does the FCC ID stamped inside make a difference, or is it the part number, or both, or neither???
This is actually for a friends A4
Old Apr 4, 2006 | 08:57 AM
maaliish's Avatar
Default if its the same remote (as in looks the same) it should work. For others, you need to check if the
frequencies and central locking are compatible. For example, I used a 2000 A4 switch blade remote on my 1997 A4 and it worked. You will also have to consider IMMO if you want the new key to actually start the car
aprA4STAGE3
Mar 12, 2007 12:30 AM
bpower1
Jan 30, 2006 12:17 PM
airtime
Oct 26, 2004 03:55 AM
Ammadeus
Aug 18, 2003 10:28 AM
311
Apr 7, 2003 08:52 AM
