Replacing swaybar bushings...
Is it reasonable to replace the bushings and bearings in the suspension on my own? I've decided that an annoying creek in my suspension is a worn out bushing on the front right. Should I replace all of the bushings once I get down to it or is one ok? The car has 101k miles, but is in very good condition; should I look into other suspension work as well?
-Tristan
2000TTQC + APR91/Stock + ComuTTer
-Tristan
Cut off this plastic bushing..>>
As it's the reason for the squeak. Replace with 20mm Powerflex bushings from TTstuff.
At 100K you should replace the upper bushings and bearings also but that is an entirely separate operation...
<img src="http://images6.fotki.com/v99/photos/7/7305/1232358/DSC02596-vi.jpg"><ul><li><a href="https://forums.audiworld.com/tt/msgs/1319039.phtml">Upper Bushing/Bearing replacement</a></li></ul>
Yes, but it's a PITA......>
Specially on the left side where there's an additional bolt that is hard to access...
(use a 1/2" or 13mm swivel headed open end/ratchet combo like a Gearwrench)
