Stupid stereo install...where to pull a REMOTE line from???
Well I wanted to pull it from the cd changer, but it looks like the changer connector cant be spliced into(to tap the acc wire)
So I need a place to run my remote wire to any ideas?(in the rear of the car!)
The wire diagram for the stock bose amp does not match up with mine at all(see link) so tapping from the amp is iffy, not sure which wire to tap? should I try them all till one lights up the amp, then electric tapr them all back together??? I s it possible to locate the ACC specific wire and tap it at the changer?
Any suggetions are welcome, I want to finish tomorrow am for waterfest
thanks i a<ul><li><a href="https://forums.audiworld.com/tt/msgs/1522013.phtml">https://forums.audiworld.com/tt/msgs/1522013.phtml</a</li></ul>
thank you jeff, I am used to ->>
pulling it from an aftermarket hu..any suggestions of where to pull from? how about thecenter console where the lock/unlock is located?
thanks again
thanks again
Re: Stupid stereo install...where to pull a REMOTE line from???
Have a little trouble understandig exactly what you mean - I am not a car stereo installer; but if this is what you looking for then
switched positive 'on' is pin 6 on this connector
<img src="http://130.74.178.25:85/AW/radio/04.jpg">
which is
<img src="http://130.74.178.25:85/AW/radio/01.jpg">
which is black wire here
<img src="http://130.74.178.25:85/AW/radio/02.jpg">
which is black wire on the very last pin 25 on Bose amp
<img src="http://130.74.178.25:85/AW/radio/03.jpg">
according to the wiring diagram
<img src="http://130.74.178.25:85/AW/radio/05.jpg">
Pics are from 2000 180FWD with Bose so your wiring should be pretty much the same.
which is
Re: thank you jeff, I am used to ->>
I see while I was typing all that and figuring out multiple pics post, Jeff put his word in. Feel rather stupid now. I suppose scrath all that in my above post then.
lyonelll
07-10-2004 10:36 AM
gram_A4TDI
07-06-2004 02:31 PM
(not a) $leeperA4
11-01-2002 10:38 AM
MikeB490
01-10-2002 05:06 PM
