temperature sensor change.
Is the sensor the cause of the erratic running, or do I need to do anything else to get the engine to idle properly? Should I bleed the coolant system? Should I run the engine for a few minutes to allow the ecu diagnostics to reset? Is there any vagcom technique that I need to know about/use?
If I go to the Audi dealer and buy an Audi/OEM sensor, and fit it, will this cure the erratic idling/engine, or will I need to get a vagcom fuel trim reset performed or similar? Could the ECU have been damaged by the sensor?
Many thanks in advance.
Thanks
36k miles
original and mint
Cluster temp rarely gets above 70c
When I run the coolant temp through climate display slowly but steadily climbs to 90c (seems to take quite a while) and sticks there. No overheating.
Cabin is warm within 5 mins.
Fuel consumption is very high - just over 10 litres per 100 kilometres of highway travel - supposed to be about 7.7 litres for every 100 kilometres of highway travel.
Any suggestions on sensors or troubleshooting?
