turbo timer
turbo timer
I previously owned a Mitsubishi Eclipse that I had modified with various HKS parts and in that car I had a turbo timer installed. This basically left my car idle for a set period of time after I take my key out of the ignition in order to cool down the turbocharger. Would this be a good thing to install in my TT you think?
I had/have one on my TT
Regardless of the factory set cooling, after driving the TT hard, I tend to let the car sit at idle for a couple of minutes until the engine temp falls to neutral before shutting down. The install is pretty straight foward and you can find it somewhere on the S4 faq section. I had to remove it along with my V1 for the Audi techs to look at my car a few months back so will probably rewire everything back in one of these weekends. The good thing about the Greddy turbo timer is that you can wire it to your emergency brake and acts as a engine cut off switch if you do not turn it off.
NY S4 driver
14
04-19-2002 06:24 PM
