Upgrade question - please advise or point in right direction
Old 09-18-2008, 06:40 AM
New Member
drnomad08's Avatar
Default Upgrade question - please advise or point in right direction
Upgrading suspension and brakes on my 2003 180FWD. Would very much appreciate recommendations. Currently have stock.
Thanks.
Old 09-18-2008, 06:41 AM
MCPaudiTT - DEFCON 1's Avatar
Street or Street/Track?
Old 09-18-2008, 06:42 AM
Budget?
Old 09-18-2008, 06:43 AM
New Member
drnomad08's Avatar
Default Re: Upgrade question - please advise or point in right direction
This will be for street. Would like to keep everything under $3K.
Old 09-18-2008, 06:55 AM
KW V1, front and rear anti-swaybars, DEFCONs, Porsche Caymen Brembo or Wilwood calipers.
Old 09-18-2008, 06:57 AM
RoberTT-WWCD's Avatar
Default Some answers...>>
For street and you like the ride height, just replace the shocks with Koni or Bilstein HDs. No need to purchase rear camber adjustment controls. If you want to lower the ride height, Eibach springs are the perferred choice here along with either Koni or Bilstein shocks. You will have to get rear camber adjusters (K-Mac or control arms) as your alignment will need them.
On brakes, one of the best upgrades is the TyrolSport's brake stiffening kit. Along with SS lines and better fluid, this will make the stock system perform like a BBK for the street.
Rotors are a personal choice, Slot and Drilled will help in rain.
Brake pad such as Mintex red Box are good street pads with little brke dust and better stopping capabilities over stock. Other s can chime in on ceramic pads.
Look at my Fotki for more...
Hope this helps.
Old 09-18-2008, 10:12 AM
BlueChip's Avatar
Default I have stock too and I'm taking a beating.....
in the Market these days. How's yours doing.
BC
Old 09-18-2008, 01:26 PM
Junior Member
BlewChip's Avatar
Default buwahahaha
not funny
Old 10-15-2008, 11:05 AM
Member
chesTTer's Avatar
Default Re: Is there a list of all the consumables that should be replaced?
Also thinking about doing my FWD with coilovers and am wondering if there is a list of everything that should be replaced/refreshed/improved while I am in there. Usage will be 90% street w/occasional track.
i.e.
tie rod ends
ball joints
Control Arm Bushings
strut mounts
position bushings
DEFCON 1/2
Thanks in advance!
qfrog Ti20
Brakes Discussion
02-12-2009 10:07 AM
cxg331
02-06-2009 10:18 AM
rs4fast
06-28-2007 05:58 PM
vtrich
12
04-13-2005 10:26 AM
crusadera4
03-18-2000 06:35 PM
Quick Reply: Upgrade question - please advise or point in right direction
