VAG Codes... ESP Light Help Please!!! G200, 01423, 57-00
01423 - Lateral Acceleration Sensor (G200)
57-00 - Electric Circuit Failure
My ESP Light is still on and I finally found someone to VAG my car, this seems to be the issue. Thanks guys. -JD
There are a few posts in the FAQ regarding the lateral acceleration code . . .
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1397162.phtml">https://forums.audiworld.com/tt/msgs/1397162.phtml</a</li></ul>
As I said :-)
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1754217.phtml">https://forums.audiworld.com/tt/msgs/1754217.phtml</a</li></ul>
and is the expensive one too...G251 is on the right side>>>
accessible via the side panel of the dash on the passenger side of the car. That is the cheaper one.....
Early cars without traction control usually only have the g251 sensor and lack the g200 sensor...
Codes are not trustworthy :-(
Unfortunately sometimes you will get a lateral code and have a bad longitudinal sensor and vice versa. At least that is what my dealer tech said and I believe I read it on here also. Regardless, when I had problems I got both 01749 and 01423 codes. Dealer changed longitudinal first. Problem came back and had to change lateral. Spent $1000 before it was over. Hope you fare better.
TTagz
14
07-21-2010 02:59 AM
Es4go
12-07-2006 04:36 AM
