Well, dealer tested my MAF and said it was within spec.
Yes.
They charged me 1/2 hour labor--reset my codes. $43. I need to get a VAG.
I think the reason it tested so good was because I just plugged it back in. They said if I had it unplugged when I got there, there would be nothing to read.
It actually may not be a problem though, because right before I plugged it back in, it died when I started it. And--it died just now when I started it to move it up into the garage.
sigh...
sigh...
All my invoice says is...
"check faults the mass air flow meter did show a sporadic fault check the value block readings were in spec at 6.3% clear fault"
Do you think if I left it plugged in for longer than a day or two, it would give enough faults in the reading to warrant a replacement?
Thanks,
Thanks,
S40RCE:Smurf
09-22-2005 03:33 PM
ChrisS -2008 A6-4.2
19
06-20-2003 05:13 AM
griza
03-28-2002 02:01 PM
