what's the consensus on adding shims/washers to the Forge DV...1 or 2? Does it matter?
Re: what's the consensus on adding shims/washers to the Forge DV...1 or 2? Does it matter?
It's about holding boost better and reacting faster. It depends on the shim. I have one 13 x 37mm. I think TTschwing adds 2 with 5 x 37mm. So about 10mm x 37mm is the point to aim at.
thanks Steve...
...I vaguely recall reading someone tried using just one, so I wasn't sure if that was as good or better. I got a 6-pack of the 35mm x 2.5mm washers, so maybe I can split the cost with a couple other people, lol.
Only 3mm more than you did....
It's ok for the turbo. VAG-Com tells me that the turbo runs free when letting off the throttle. It's ok for me. Boost is rising very fast everytime I push the throttle.
T-dot B6
09-13-2004 03:08 PM
HASTTA
07-23-2004 08:15 PM
Boston1.8T
12-03-2003 06:58 PM
CharlieGSanD
07-11-2002 07:34 AM
