Wilson Manifolds?
long story short...
(picture of the TB end of manifold)
<img src="http://pictureposter.audiworld.com/30768/throttlebodyendmanifold.jpg">
Besides a very cool machining into your manifold 16% greater flow to the combustion chamber from the turbo. The mod is not the best first mod but is more a stage II mod in preparation of a bigger turbo. Actual VAG readings will be forthcoming and it will be dynoed as well to document the HP improvements.
<img src="http://pictureposter.audiworld.com/30768/installedmanicloseup.jpg">
The retail cost is around 1,500 for both the manifold and throttle body work. Although a group buy could well be arranged. The manifold by itself is about 800.
Re: 16% greater flow to the combustion chamber from the turbo
Not exactly, 16% greater from the entrance of the intake manifold to the exit of the manifold, with a similar gain on throttle body.
Increase is less.
Take a 1/2" garden hose and measure the flow rate, then take same length 5/8" hose and measure. 5/8" will flow more. Compare flow increase. Now add 1/2" hose to it and measure, flow rate will be less than either alone. Then measure 2 lengths of 1/2" hose flow will be even lower. Compare flow increase. Increase when going from 1/2 + 1/2 to 5/8 + 1/2 will be less than increase from 1/2 to 5/8.
No change from turbo to throttle body and no change from manifold outlet to combustion chamber. So increase is less than 16%. Data so far shows 10% increase including other mods.
