VAG-COM Discussion
Active steering no basic setting
Old Aug 24, 2011 | 11:27 AM
roet's Avatar
Default Active steering no basic setting
Hi,
This S5 will not go past basic setting foor the angle sensor.
I tried several times without succes.
In ABS i do security access 40168, wich is accepted as login, in group one i get locked without any change when i drive under 20.
I tried first removinbg all faults and then drive it, but no luck.
What am i doing wrong?
Thanks in advance!
Thursday,18,August,2011,08:34:44:04043
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 8T0
Scan: 01 02 03 05 06 07 08 09 0E 10 14 15 16 17 19 1B 20 36 37 42
46 47 52 53 55 56 6C 77
VIN: WAUZZZ8T49A025715 Mileage: 43980km/27327miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAUA) Labels: 079-907-560-CAU.clb
Part No SW: 8T0 907 560 C HW: 8T0 907 560
Component: 4.2l V8/4V H10 0002
Revision: 76H10---
Coding: 01140003190F0120
Shop #: WSC 06325 000 00000
VCID: 3A70C4A60CCF
2 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 001 - Upper Limit Exceeded
P1653 - 008 - Implausible Signal
Readiness: 0010 1001
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 B HW: 0B6 927 156
Component: 0B6 42 FSIRdW H04 0040
Revision: --H04---
Coding: 001001
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 356AD79A25D1
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 126D00
VCID: 7BFE01A24375
4 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit - MIL ON
03110 - Active Steering Control Module (J792)
013 - Check DTC Memory
00473 - Control Module for Elect. Park/Hand Brake (J540)
03159 - TPMS Functionality in ESP
000 - -
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DQ HW: 8K0 907 064 DQ
Component: BCM2 1.1 H02 0327
Revision: 00002001
Coding: 010000
Shop #: WSC 00321 211 180609
VCID: 8200FC46A49F
Part No SW: 8T0 959 754 Q HW: 8T0 959 754 Q
Component: FBSAUDIB8 IDG H37 0060
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001157657
Coding: 00017025002C00000000
VCID: 4280BC46641F
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 P HW: 4E0 035 729 A
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 331J-087529736
Coding: 0025001
VCID: 4688A0564837
Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0140
Revision: A1000000 Serial number: 0123.09.080310
Coding: 48020000
VCID: 70E4268E1A33
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000140336
Coding: 260050914074AF311F09000300005D5D0F9CC3C80001012100 0000
VCID: 3064E68EDAB3
Part No SW: 8T1 955 119 C HW: 8J1 955 119
Component: WWS 161008 H13 0040
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 02532C
Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Part No SW: 8K0 907 410 HW: 8K0 907 410
Component: EHL205.06.02K H02 0010
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043003 Serial number: AUZ5ZBH8624984
Shop #: WSC 00000 000 00000
VCID: 2A50F4E6FC6F
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 E HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0020
Revision: 11001001 Serial number: 52840828703851
Coding: 300102
VCID: 3B7EC1A203F5
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0052
Revision: 00000000 Serial number: 08100809240002
Coding: 050181
Shop #: WSC 49468 150 84267
VCID: F0E4A68E9A33
3 Faults Found:
03263 - Functional Restriction
000 - - - MIL ON
03155 - Functionality limited due to Initialization
000 - -
03264 - Functionalty Shut Off
000 - - - Intermittent
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1BP0UO
Coding: 30313433363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7CC2BE06FB
Driver's Airbag Crash Sensor:
Serial number: 6334MSME42015661+
Passenger Side Airbag Crash Sensor:
Serial number: 6344MSME42452C7BL
Driver's Rear Airbag Crash Sensor:
Serial number: 6352QSME2D0E4C36V
Passenger's Rear Airbag Crash Sensor:
Serial number: 6362QSME060F3732E
Passenger's Front Airbag Crash Sensor:
Serial number: 63832SME246D455FB
1 Fault Found:
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open Circuit
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90315HIQ000DP
Coding: 000036
VCID: 3E78C8B610E7
Component: E221 - MFL H02 0003
1 Fault Found:
01316 - ABS Control Module
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 B HW: 8T0 920 931 B
Component: KOMBIINSTR. H31 0224
Revision: 00100000 Serial number: 9D775NEA8
Coding: 0F0701003B000008000000
VCID: 3668D09638D7
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0094
Revision: 4FB50047 Serial number: 4700F08923819C
Coding: 000303
VCID: 4A9094665C2F
Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 C HW: 8K0 907 144 C
Component: DYNAMIKLENK. H06 0500
Revision: 50001003 Serial number: --------------
Coding: 840000
Shop #: WSC 06324 000 00000
VCID: 2F66E5F2C78D
1 Fault Found:
01087 - Basic Setting Not Performed
000 - - - MIL ON
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 B HW: 8K0 857 511
Component: FLA H04 0003
Revision: AA001002
Coding: 02019864747464545425363E
VCID: 3064E68EDAB3
1 Fault Found:
03453 - Functional Restriction due to Implausible Message(s)
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001162893
VCID: 4280BC46641F
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H52 1050
Revision: 00000000 Serial number: 333JZ087623369
VCID: 3064E68EDAB3
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: cH…
Coding: 011C022250002201
VCID: FDFA8FBADD61
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0127108952
Coding: 01000680003940840030000000000000
VCID: 8200FC46A49F
Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Address 47: Sound System (J525) Labels: 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 AD HW: 8T0 035 223 G
Component: DSP STD H08 0300
Revision: S2600000
Coding: 010101
VCID: 70E4268E1A33
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: b…ƒ
VCID: FCFC82BEC67B
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 10000000113885
VCID: 3162E38AD1B9
1 Fault Found:
013 - Check DTC Memory - MIL ON
Address 55: Xenon Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 3064E68EDAB3
Part No: -----------
Component: AFS-Modul links
Component: AFS-Modul rechtsH01 0008
1 Fault Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336J3087605998
Coding: 0000001
VCID: 2E58F8F6C087
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J8991SV
Coding: 1021008
VCID: 3776DD923FDD
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H11 0960
Revision: 00H11000 Serial number: 00000007592866
Coding: 0010011
VCID: 244C1ADE9E4B
End ---------------------------------------------------------------------
Wednesday,24,August,2011,21:19:27:04043
Chassis Type: 8T0
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
Revision: 76H10---
VCID: 3A70C4A60CCF
2 Faults Found:
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 9
Mileage: 43986 km
Time Indication: 0
Date: 2011.08.24
Time: 17:57:38
Freeze Frame:
RPM: 701 /min
Load: 36.5 %
Speed: 0.0 km/h
Temperature: 56.0°C
Temperature: 24.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 10
Mileage: 43986 km
Time Indication: 0
Date: 2011.08.24
Time: 17:57:38
Freeze Frame:
RPM: 701 /min
Load: 36.5 %
Speed: 0.0 km/h
Temperature: 56.0°C
Temperature: 24.0°C
Voltage: 13.970 V
Readiness: 0110 1001
Revision: --H04---
Coding: 001001
VCID: 356AD79A25D1
Coding: 126D00
VCID: 7BFE01A24375
1 Fault Found:
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 199
Mileage: 43987 km
Time Indication: 0
Date: 2011.08.24
Time: 21:09:15
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x000D
Hex Value: 0x3396
Hex Value: 0x00FF
Revision: 00002001
Coding: 010000
VCID: 8200FC46A49F
VCID: 4280BC46641F
Coding: 0025001
VCID: 4688A0564837
Coding: 48020000
VCID: 70E4268E1A33
VCID: 3064E68EDAB3
Coding: 00FD11
Coding: 02532C
VCID: 2A50F4E6FC6F
Coding: 300102
VCID: 3B7EC1A203F5
Coding: 050181
VCID: F0E4A68E9A33
VCID: 3C7CC2BE06FB
Driver's Front Airbag Crash Sensor:
Serial number: 63732SME150E1A0E1
Coding: 000036
VCID: 3E78C8B610E7
VCID: 3668D09638D7
Coding: 000303
VCID: 4A9094665C2F
Coding: 840000
VCID: 2F66E5F2C78D
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
Count: 56
Count: 1
Hex Value: 0x0075
Hex Value: 0x761A
Hex Value: 0x0B00
Hex Value: 0xFFFF
Revision: AA001002
VCID: 3064E68EDAB3
VCID: 4280BC46641F
VCID: 3064E68EDAB3
VCID: FDFA8FBADD61
VCID: 8200FC46A49F
Revision: S2600000
Coding: 010101
VCID: 70E4268E1A33
VCID: FCFC82BEC67B
VCID: 3162E38AD1B9
Coding: 0000018
VCID: 3064E68EDAB3
Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Component: AFS-Modul rechtsH01 0004
Coding: 0000001
VCID: 2E58F8F6C087
Coding: 1021008
VCID: 3776DD923FDD
Coding: 0010011
VCID: 244C1ADE9E4B
JohnstonAG
Q7 MK 1 Discussion
Mar 8, 2017 11:24 PM
ceroberts75
Jul 16, 2016 09:20 AM
snatchman
Aug 28, 2013 03:52 AM
monzer ferwana
VAG-COM Discussion
Nov 27, 2012 10:47 AM
MainlandMig
VAG-COM Discussion
10
Feb 25, 2012 09:29 AM
