Assistance needed recoding ABS module and bleeding brake system
I need some assistance with recoding my ABS module and bleeding the brake system on a MY2002 A6 2.7T 6MT with ESP program. In addition I have a Bosch 5.7 module not the usual 5.3.
I installed a new module and valve body and need to recode the module. My original coding for the module was 06395. The only recode info I can find is on ross-tech website
http://www.ross-tech.com/vag-com/cars/espcoding.html . That article references a login of 09495 for a 2.7T Manual and to use code 04395. My original code is 06395 but it will not take that code with the 09495 login. Does anyone know what the login would be for coding 06395?
I was able to successfully code the module as 04395 and now I have the codes below and still cannot cycle the ABS unit to bleed the system.
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
When I try to enter the basic code of 002 to cycle the ABS unit, I get an error. I am running a very old version of VAG-COM and a 3rd party cable that should work and am planning on purchasing the new cable and software but would like to get the car on the road tomorrow and it will take a few days to get the new equipment. Any help would be appreciated.
My car is on jackstands! :--(
Thanks,
Lonnie
2 Faults Found:
35-00 - -
Thanks,
Lonnie
The page you referred to is for A4's and Passats, it does not apply to your A6.
If your original coding was 06395, then according to <a href="http://www.bentleypublishers.com/product.htm?code=ADC5">Bentley</a>, the corresponding Login should be 07495.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Re: The page you referred to is for A4's and Passats, it does not apply to your A6.
Thx. Where did yo ufind that info in the Bentley manual? I was looking and could not find it.
See the link Uwe pointed you too or the following entry in our WIKI...
<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_A6_%284B%29_Brake_Electronics_%28Bosch_5.7%29 ">http://wiki.ross-tech.com/index.php/Audi_A6_%284B%29_Brake_Electronics_%28Bosch_5.7%29 </a</li></ul>
kgardnez
09-15-2020 01:26 PM
llonman
05-01-2007 07:01 AM
