Boost block and other helpful blocks
anyone know what block is the turbo boost value? My car is lagging a bit in the higher RPM range, i think it might be the BPV, but i would like to monitor boost and any other helpful blocks.
block 115...
3rd and 4th cells are requested and actual boost in miliBAR. around 1000 miliBar is atmosphere so under pressure you should see 1.5 bar non chipped and 2+ bar chipped.
Also take a look at block 114, the 4th cell is the wastegate control valve (n75). It tells you about how much the ECU is controling the boost. If you're in limp mode, this number might only get up to 50% while nonlimp mode this will go to 95%
Kirk
Kirk
ImQuattro®
Audi Original "S" Cars
01-27-2009 01:12 PM
DM-S4
06-07-2004 10:26 PM
greatwhitecaper
25
12-01-2002 06:25 AM
