VAG-COM Discussion
Connection Problem!!!
Old May 27, 2005 | 02:45 PM
ekA6's Avatar
New Member
Default Connection Problem!!!
When I connect to my 98 A6 I always recieve an error: incorrect com port, interface not in, ignition off, k-line stuck. I have check all the fuses, the com port is set to com 1(which is correct), and have the igntion on.
I tried connecting it to a friends 01 A4 and it works fine. I've had it working in the past. I'm using the latest version of the software.
I'm confident that the problem is in the car, since it worked before and on another car. Anyone change something on their car to fix this problem.
Old May 27, 2005 | 02:49 PM
Theresias's Avatar
Default Define "latest software version", at least tell a specific version number. Also tell us which...
...hardware (interface) you are using.
Old May 27, 2005 | 03:40 PM
ekA6's Avatar
New Member
Default Re: Define "latest software version", at least tell a specific version number. Also tell us which...
311.2 using the old opto-coupler interface
Old May 27, 2005 | 06:25 PM
Uwe@Ross-Tech.com's Avatar
Banned
Default If it works from the same PC on another car,
then the problem is this car. The two most common things would be:
* No power (+12V) available on Pin 16 of the car's diagnostic socket
* An issue with the radio. See the link below.
-Uwe-<ul><li><a href="http://www.ross-tech.com/vag-com/aftermarket-radio.html">http://www.ross-tech.com/vag-com/aftermarket-radio.html</a</li></ul>
Old May 27, 2005 | 09:43 PM
AUDIS4BI:Vintage's Avatar
Default damn, I'm having the same type of problem...
It didnt work at all with the newest version, the 311.version atleast got through the test but I got the same error when I went into the engine section...<ul><li><a href="https://forums.audiworld.com/s4/msgs/2011225.phtml">https://forums.audiworld.com/s4/msgs/2011225.phtml</a></li></ul>
Old May 30, 2005 | 11:34 AM
Hofman
New Member
Default Re: damn, I'm having the same type of problem...
"It says com port status:OK .."interface status:5-Modem!" I pressed save then when I go into the engine catagory it says : Interface Status=5, Interface not ready! Possible reasons : incorrect COM port selected, interface not plugged in, ignition not turned on, K line Stuck"
Com 5 most likely is a modem. Go into windows device manager and see what com ports you have. also dissable any IR device. than go back to Vag-Com and select one of the ports you found in device manager. (usually com 1 or 2)
Old Jun 2, 2005 | 09:23 AM
ekA6's Avatar
New Member
Default Re: If it works from the same PC on another car,
There is 12 volts on pin 16 and I don't have an aftermarket radio. Any other suggestions, thanks.
spence341
9
Mar 3, 2010 05:06 PM
Kingttr
Jan 10, 2008 09:39 PM
drgallo
Jul 17, 2007 06:09 AM
RXBG
Oct 22, 2005 08:16 AM
phins
Sep 29, 2001 04:59 PM
