Difficulty with DTC's
Motor revs to high high rpms and quickly does ground out thing. The Boost pressure valve has 3.5 volts and 30 ohms resistance, so i am assuming it is good, but haven't been able to visually inspect this as of yet. No accelerator(limp mode) Your help greatly appreciated.
VCDS-Lite Version: Release 1.2
Monday, 02 February 2015, 13:59:18.
Control Module Part Number: 8N0 906 018 K
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 06710
Work Shop Code: WSC 24338
VCID: 3905AEE73041
Additional Info: TRUWT28N511041187 AUZ5Z0A3020023
9 Faults Found:
18039 - Accelerator Position Sensor (G79): Signal too High
P1631 - 35-00 - -
18042 - Shareware Version. To Decode all DTCs
P1634 - 35-00 - Please Register/Activate
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-10 - Please Register/Activate - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
16727 - Shareware Version. To Decode all DTCs
P0343 - 35-00 - Please Register/Activate
17956 - Shareware Version. To Decode all DTCs
P1548 - 35-10 - Please Register/Activate - Intermittent
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-10 - - - Intermittent
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
16522 - Shareware Version. To Decode all DTCs
P0138 - 35-00 - Please Register/Activate
Monday, 02 February 2015, 14:04:16.
VCID: 3905AEE73041
9 Faults Found:
P1631 - 35-00 - -
VCID: 3905AEE73041
9 Faults Found:
P1631 - 35-00 - -
VCID: 3905AEE73041
9 Faults Found:
P1631 - 35-00 - -
VCID: 3905AEE73041
9 Faults Found:
P1631 - 35-00 - -
VCID: 3905AEE73041
9 Faults Found:
P1631 - 35-00 - -
VCID: 3905AEE73041
9 Faults Found:
P1631 - 35-00 - -
VCID: 3905AEE73041
9 Faults Found:
P1631 - 35-00 - -
shwndh
05-20-2006 05:16 PM
AxeYrCat
33
05-13-2005 03:44 PM
