found a fault while doing an AutoScan... any ideas what it might be?
Address 01: Engine
Part No: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0003
Coding: 0016701
Shop #: WSC 63351
1 Fault Found:
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Coding: 0016701
Shop #: WSC 63351
1 Fault Found:
a number of things...
gas cap seal, small crack in an evap hose, or the likely one: EVAP purge valve not closing completely on occasion.
Run basic setting 070 and 191, even though I'm sure it will pass ok, you may see something there that may indicate a sealing problem or purge valve problem
thanks...
now that you're mentioning it, it might be from the gas cap. it kept failing when i took the Avant through the smog test/control. we all thought at the time that it couldn't be the gas cap. we've kind of assumed since the car is only 3 years it had to still be in good condition... well maybe not...
pane2k
12-02-2007 11:56 AM
dang
10-02-2007 08:19 AM
Avantéix
9
02-03-2006 05:24 PM
