Measuring blocks not available on EDC17 ecu equipped cars
I've noticed that measuring blocks are not available on those cars, anyone know something about this "issue"?
Thx in advance
Thx in advance
Year? Make? Model? Engine Code? Auto-Scan?
There is no general issue with measuring values on EDC17 ECUs, but depending on the exact vehicle you are having there its possible we are missing sth.
I did not try autoscan, but measuring blocks remains gray.
The reason I asked for the Auto-Scan was because I'd like to double check if the control module in question is covered by VCDS with all necessary data to actually give you some measuring values.
In this case measuring values are not supported by VCDS Release 805, since your ECU uses the new UDS/ODX protocol I suggest you try VCDS Beta 812 instead.
http://www.ross-tech.com/vcds/downlo...a/current.html
it's not working with CAGA either...i spoked on another forum with Bruce about that and he asured me they will try to fix it asap.
I tried 812 805 and 904, measuring blocks, advanced measuring blocks and no results
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JN HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3174
Revision: 11H01---
Coding: 0104002C02072118
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TDI03L906022JN A01004
ROD: EV_ECM20TDI03L906022JN.rod
No fault code found.
Readiness: 0 0 0 0 1
Revision: 11H01---
4Rings::G2 boosted::
09-14-2008 06:50 PM
BlackS4tt (Josh)
01-19-2006 10:10 PM
agent s
07-30-2001 10:03 AM
