VAG-COM Discussion
Q7 MMI system is dead, ran codes
Old Oct 29, 2011 | 08:47 AM
old96A4's Avatar
Default Q7 MMI system is dead, ran codes
I'm trying to figure out what to check or replace. I ran an auto can on the car, had some other issues too. but I knew of some of the others, just trying to fix the MMI system right now, cold morning , turned it on and nothing, worked the night before. the screen comes on for a few seconds and then nothing, none of the buttons works or come on. wonder if I can get any info. why is there no communication to any MMI function?? acts like there is no power like a fuse went or the optical bus is bad??
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 37 3C 42 46 47 4F
52 55 56 61 62 65 67 69 6C 6F 72 76 77
VIN: WA1BY74L77D068355 Mileage: 79560km/49436miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: Cannot be reached 1100
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 05: Acc/Start Auth. Labels: None
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100602951
Coding: 0000135
Shop #: WSC 31414 790 00001
VCID: E3CED0A15BCE
Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
4 Faults Found:
00193 - Right Rear Door Handle Touch Sensor (G418)
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 17
Reset counter: 128
Mileage: 67305 km
Time Indication: 0
Date: 2011.03.25
Time: 13:46:18
00191 - Passenger's Door Handle Touch Sensor (G416)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 179
Mileage: 69259 km
Time Indication: 0
Date: 2011.04.11
Time: 13:34:31
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 11
Reset counter: 155
Mileage: 69326 km
Time Indication: 0
Date: 2011.04.12
Time: 18:44:17
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 126
Mileage: 69604 km
Time Indication: 0
Date: 2011.04.18
Time: 12:16:28
Address 07: Control Head
Cannot be reached
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06B138009
Coding: F757DE77747A02
VCID: ECDCBB9DB610
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Mileage: 79539 km
Time Indication: 0
Date: 2011.10.28
Time: 07:49:08
Address 1E: Media Player 2
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: 0
Coding: 0051787
VCID: 2F66EC91C786
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 116
Reset counter: 147
Mileage: 77898 km
Time Indication: 0
Date: 2011.09.27
Time: 16:05:31
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01025882110000
Coding: 4487197
VCID: 3162EAE9D1B2
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
03073 - Rear Lid Closed Sensor 1
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 112
Mileage: 79082 km
Time Indication: 0
Date: 2011.10.16
Time: 16:11:55
Address 47: Sound System
Cannot be reached
Address 56: Radio
Cannot be reached
Address 67: Voice Control
Cannot be reached
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002211739-----
Coding: 0003595
VCID: 264809B5E87C
Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Component: J_394_EE15_SKB09H10 0180
Component: J_392_EE15_SKB09H10 0180
1 Fault Found:
01516 - Terminal 30; Left
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 147
Mileage: 79560 km
Time Indication: 0
Date: 2011.10.28
Time: 17:48:45
Address 77: Telephone
Cannot be reached
Old Nov 7, 2011 | 04:46 PM
Uwe@Ross-Tech.com's Avatar
Banned
All those systems which "Cannot be Reached" talk to the CAN Gateway by means of an optical MOST bus. This is a "ring" architecture bus, and any break in the ring, either in the optical cabling or due to a bad module, will take the entire MMI system off-line. However, Audi was smart enough to include a means of diagnosing such problems, and VCDS supports it too. Click [Applications] -> [Optical Bus Diagnostics] and post the results. Hint: The [Copy] button will put the results in the Windows Clipboard and the [Save] button will put the results in a plain-text file for you.
-Uwe-
Old Nov 11, 2011 | 09:36 AM
old96A4's Avatar
Thanks, I saw that on your web site , I'm going to try it. still learning with the thing. I did buy a loop back coneector so i can take things out of the loop to see which one is bad. been doing a lot of reading on the MOST bus. System shuts donw when the main control board can't get back what it put out. Thanks I'll post it when I get the time to run it..
Old Dec 8, 2011 | 02:21 PM
old96A4's Avatar
The dealer wanted to take a look at it, the power amp to the MMI system was shot from water leaking on it from the sun roof drain that had come off. Bad seal or something. Never really got a chance to debugg it , dealer did it for me. they had done work on teh sun roof last March , cobered thg ewhole thing under warranty of work that was done last March..
ceroberts75
Jul 16, 2016 09:20 AM
Crai6m4ck
VAG-COM Discussion
Jan 6, 2016 06:17 PM
snatchman
Aug 28, 2013 03:52 AM
tashakes
VAG-COM Discussion
Oct 13, 2011 06:51 PM
CPO1
Apr 20, 2011 10:41 AM
