S5 unresponsive to key, camera glitch, and garage opener
Hi Audi fans, I'm new to the forum. I have a 2010 S5 with less than 20k miles. I've experienced the following so far:
Doors/trunk doesn't open when unlocking or locking with the key. I already changed the battery 2x. The key indicator flashes so it can't be the key. It takes 1-2 minutes for the car to finally respond. I have the garage opener Programmed by the car, today the garage wouldn't open again 1-2 minute delay both exiting and entering. The indicator flashes that it's transmitting.
The last issue only occurred 2x so far: the back up camera glitched and disappeared when I shifted into reverse; but that went away by turning the car off. What do you guys think? I really love this car, but im almost 2 months in.
Suggest you find someone with VCDS and scan the Central Convenience and Central Electronics modules to see if they are showing fault codes./
Yes they can - by limited warranty do you mean Audi's CPO (Certified Pre-Owned). Give the dealer a call and ask them if there is a minimum charge. When my B6 was under CPO, there was a fixed $100 charge for each CPO warranty repair I needed.
It's a warranty to cover 4k miles or 3months. Whatever comes first. It faults maybe once a week. I'll have Audi run for faults.
akingzkid
16
04-16-2023 09:51 AM
Hulk1906
Telematics Discussion
07-09-2017 06:39 PM
