EDIT: Gary, do you have special hub centric rings to take up slack with a particular wheel?
I need about 2mm ones to take up slack at the hub and Abt SPO wheel currently using 5mm spacer to clear the brembo's...that 5mm may be the culprit.
Re: Gary, do you have special hub centric rings to take up slack with a particular wheel?
Slim chance, but can check. What inner and outer measurements would the rings need to be ? (in millimeters)
54.1 wheel bore (after taper) and 57.1 mm centering hub
H&R 5mm spacer over 57.1mm hub...
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/sol054.jpg">
note the taper in the wheel bore: inside wheel bevel: 7.0 x 45*
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/Picture039.jpg">
Horch it
Wheels & Tires Discussion
08-18-2008 10:24 AM
A4_Jax
05-21-2004 10:14 AM
Jack Wang
07-05-2002 05:17 PM
