How to prep calipers for painting? Advise needed
I just purchased a can of POR-20 Hi Temp (1400 deg) bright aluminum paint for my brake calipers on my Aluminum Silver 2.8. I'm going to use a brush but I need advise on how to prep? Do you recommend sanding, wire brushing, chemical cleaning? I will NOT be removing the calipers I want to paint in place.
TIA
TIA
Here is how I did it:
I used brake cleaner to soak the calipers, a wire brush and a toothbrush to thoroughly remove all dirt and brake dust from the calipers, then tape off and cover all parts you dont want painted and then shoot!
Good luck, post pictures when you are done!
ReTodd
Auto Detailing Discussion
12-20-2004 06:58 AM
TTnUrFace
08-11-2002 09:18 AM
