Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Peoples' opinions on winter tires...all season vs snows?
Old Oct 9, 2001 | 11:16 AM
Ray Khan's Avatar
Default Peoples' opinions on winter tires...all season vs snows?
I live in Boston...I had no problems with my stock 15" wheels with all season tires(whatever all season tires come stock) in last years snow. I heard snow tires aren't as good on pavement as all seasons are. With that said, the actual amount of time one would be driving on snow in New England is probably no more than 15 hours through the winter. Also, I heard that snow tires wear quickly to the point where there are more like an all season tire than a snow tire. This makes me think an all season tire for my winter wheels is going to make more sense than a snow tire? What do you think?
Old Oct 9, 2001 | 11:52 AM
RaudiA7's Avatar
Default Get a set of winter wheels/tires
I would get a set of 16" wheels and tires (blizzak vs. dunlop wintersports)from the tire rack. will cost you between $500 and $1000. Big difference in snow and ice (antilock brakes don't keep kicking in), dry driving is fine. don't have to worry about scratching your nice rims. saves tread on your expensive tires, Tires will last 3 or 4 seasons.
I was very satisfied with the set up on my A4
Old Oct 9, 2001 | 12:02 PM
HobbittCar's Avatar
New Member
Default Re: Peoples' opinions on winter tires...all season vs snows?
I've had both all seasons and snows in the Boston area within the past few years. I thought the all seasons were fine until I got the snows.
HUGE difference (to me anyway)
You point out 2 things in your post.
1. The dry performance of snows is not as good as all seasons.
2. How much do you *really* drive in the snow.
1. How hard do you drive your car? Do you really care if you can't corner as fast in the snows?
2. You may only drive 1 hour in the snow. If you're not scared s**tless for 1 hour each year, is the $500 worth it? I had to move apartments during one snow storm last year. I saw over 20 people off the road that day as I drove. Worth the money? To me, yes.
Hope this helps, and good luck with your decision.
- dave
Old Oct 9, 2001 | 12:12 PM
Ray Khan's Avatar
Default good perspective....I want to do big brakes at some point...
this will require bigger winter wheels. I'll probably go with some snows then when I do the upgrade. Thanks for your advice.
Old Oct 9, 2001 | 06:16 PM
Bill S's Avatar
Default I've had good luck w/Michelin Arctic Alpins
Dry performance is excellent for normal driving. If you're into drag racing on off-ramps, you might be disappointed. If you're interested in getting to your destination safely and with nice, tight handling you'll be happy.
Performance on ice is unbelievable. No comparison to all -seasons. Snow performance is excellent, though other tires will be a bit better in deep snow, not a common condition on the roads here. Ice is the big danger (I'm in the Boston area, too).
Mine have worn like iron. After three winters, mine still have 9/16" tread left. And these tires have their special ice compound all the way through the tread, so even when they wear down more they will retain much of their cold-weather performance.
I suggest getting 15" steel wheels for best snow and ice performance, plus economy.
Old Oct 10, 2001 | 07:41 AM
Eddie@Tirerack's Avatar
Member
Default you would do well with a bit more of a 'performance' winter tire....
A tire like the Dunlop WinterSport M2 for example is designed with a lot of dry road handling in mind & will attack & perfrom in ice & snow MUCH better than any all season can do, plus the tires are designed to operate in the colder temp range than what an all season tire will.
Call me to discuss in more detail!
Eddie
Old Oct 10, 2001 | 10:42 AM
Ray Khan's Avatar
Thanks Eddie...I'll give you a call when I'm ready to buy
ssankar
Florida Discussion
Aug 1, 2002 09:03 AM
Surfdamtns
Oct 9, 2001 09:11 AM
Chris In Philly
12
Apr 4, 2001 08:41 AM
pking
Oct 12, 2000 07:26 AM
Reggie
Sep 28, 1999 06:25 AM
