Down pipe removal- WTFudge?
Old 07-24-2016, 04:32 PM
Carbunkle's Avatar
Default Down pipe removal- WTFudge?
Trying to remove downpipes to weld in new flex pipes. Others have done it. Have no idea how, maybe on younger cars. I just need to know it can be done w/o dropping the engine. Do the shields have to come off or is it just easier? Looks like there's access to all bolts to some extent. Did this on a 6sp Passat V6. Add turbos and a fat *** tip trans yeesh! Wanted to leave pulling the engine for when the turbos go.
Old 07-25-2016, 06:12 PM
Prospeeder's Avatar
You remove those shields, support the engine, and lower the subframe down till you can access all the bolts. They are insanely tight....good luck.
Old 07-25-2016, 07:12 PM
Carbunkle's Avatar
Default Cool thanks
So I drop the whole subframe straight down. I have a trans jack that should be able to handle it. Thanks a lot.
mikesquattro
Audi allroad
12
05-06-2008 05:03 PM
sphere
06-29-2007 09:01 PM
Catapult
08-25-2005 04:50 PM
almoniyot
06-30-2005 08:27 PM
BS4
03-04-2003 03:14 PM
Quick Reply: Down pipe removal- WTFudge?
