Rear Brake Bleed, Parking Brake Adjustment
#11
The brakes are 'working" fine, just not as firm as I 'thought' they were before the rotors and pads.
Also, the first press after having the parking brake set and released seems a little further (why I was thinking there was a parking adjustment step I might have missed)
Someday I might get a pressure bleeder, as they seem to be more important now that everything has ABS.
I may just get a suction bleeder and pull another few OZ out and see what happens.
Maybe I am being too picky.
The softness on the pedal could be due to new pads seating in OR there is air in the system.
To sleep better at night, the simple thing to do is a complete flush like I mentioned in previous posts. No need for any vacuums or special brake bleeder tools. A small hose, wrench and 3 cans of fluid is all you really need. Ok, maybe a helper to pump brakes while you watch the bubbles...
Seriously, I am just as picky (if not worse) so, do what I did and you won't have any issues.
Personally, I am very cautious about brakes more than anything else on my car (well, that and cleanliness of the windshield/mirrors).
#12
After reading about the potential problems of bleeding brakes the old fashioned way (2 people, one at the brake opening and closing the valve, and one pumping the brake pedal) I bought a pressure bleeder. Gotta say that I was amazed at how simple the bleeding process became. I was hesitant to buy yet another tool as I am cheap and just didn't want another specialized tool.
Just like I forced myself to use one of those $10 universal cubes to back in the caliper piston. Oh I hated that. Finally bought the proper tool. What a difference. Now doing brakes is much quicker and I don't hate the job.
#13
Well, the Motive is ordered.
If I flush 3 cars and save a can of fluid each, I have paid off the tool.
Well, almost, I still have the issue with "Yet another box showing up on the doorstep" that I have to explain to my wife.
#14
Yeah, the rear brakes are not that useless. I agree. But adjusting the parking brake has nothing to do with how the brake pedal feels. You prolly know that and you're just mentioning it as an extra PITA. But the only reason you would want to adjust the parking brake is if the pads are low. Not after you bleed. Just my 2 cents. If you have air in the line adjusting the parking brake cable won't take care of the issue
#15
If she is no longer required to assist in the 2 person bleed then she may accept the box. Otherwise, get a bid from your local indy to bleed all three cars. Plus the time and hassle of jockeying the cars to/from. Surly the box is the lesser of evils.
#16
The parking brake handle works OK, but pulls up a tad more then I like. Is there and easy adjustment?
#17
Still, I agree with you on this. Tools definitely make the job easier, faster and safer. Sometimes, the tools don't do what they are supposed to and that's where I revert to old methods. Take Oil filter in my 4.2 for example. There are so many filter removal tools but with space constraints, getting them and turning/removing them is a PIA. You know what works? A big old Adjustable pliers - every single time! just my $0.02.
#18
Typically with Disk brakes I would not expect the parking to have an effect, but it just "seems" that applying and releasing the parking brake affects the peddle feel. Was thinking maybe after turning in the rear piston, I missed a step.
#19
Even if I never use my Powerbleeder again, it was money well spent, especially because I know the job was done right... Now if only it was easier to order the blue ATE fluid still to make the bleeds easier to notice in the US.
#20
Change it ever 2 years and even 4 year old fluid is not that bad, and there will certainly be nothing older the 4 years anywhere in the system.
DannyG123US
09-07-2015 05:53 PM
stormchaser1967
09-02-2015 09:26 AM
